Compare Ignition 8.1.35 vs 8.1.45
Is there a quick way to compare all the features of 8.1.35 vs 8.1.45.
You can trawl through the nightly changelogs. Go back to find 8.1.35 and then page through. It's not as bad as it sounds as the changes are listed under module headings do, for example, if you are interested in changes to Reporting you should be able to find them quite easily.
