Comparison method violates its general contract!
I have a problem with the tags; infact inside the gateway does not work in the tag the valueChanged.
When I create a new project in the output console I have this error:
Exception in thread “AWT-EventQueue-2” java.lang.IllegalArgumentException: Comparison method violates its general contract!
at java.util.TimSort.mergeHi(Unknown Source)
at java.util.TimSort.mergeAt(Unknown Source)
at java.util.TimSort.mergeForceCollapse(Unknown Source)
at java.util.TimSort.sort(Unknown Source)
at java.util.Arrays.sort(Unknown Source)
at sun.awt.datatransfer.DataTransferer.setToSortedDataFlavorArray(Unknown Source)
at sun.awt.datatransfer.DataTransferer.getFlavorsForFormatsAsArray(Unknown Source)
at sun.awt.datatransfer.SunClipboard.getAvailableDataFlavors(Unknown Source)
at com.inductiveautomation.ignition.designer.sqltags.dialog.TagBrowserPanel$TagBrowserActionHandler.canPaste(TagBrowserPanel.java:468)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.updateEditActions(IgnitionDesigner.java:2832)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$SetEditActionHandler.run(IgnitionDesigner.java:3072)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$4.actionPerformed(IgnitionDesigner.java:2214)
at javax.swing.Timer.fireActionPerformed(Unknown Source)
at javax.swing.Timer$DoPostEvent.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.stateChanged(IgnitionDesigner.java:2838)
at com.inductiveautomation.ignition.designer.model.AbstractEditActionHandler.fireChangeEvent(AbstractEditActionHandler.java:37)
at com.inductiveautomation.ignition.designer.sqltags.dialog.TagBrowserPanel$TagBrowserActionHandler.valueChanged(TagBrowserPanel.java:453)
at javax.swing.JTree.fireValueChanged(Unknown Source)
at javax.swing.JTree$TreeSelectionRedirector.valueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.fireValueChanged(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.notifyPathChange(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPaths(Unknown Source)
at javax.swing.tree.DefaultTreeSelectionModel.setSelectionPath(Unknown Source)
at javax.swing.JTree.setSelectionPath(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI.selectPathForEvent(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.handleSelection(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressedDND(Unknown Source)
at javax.swing.plaf.basic.BasicTreeUI$Handler.mousePressed(Unknown Source)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
How do I fix?
What version of Ignition are you using? What version of Java on the server?
I solved by uninstalling and reinstalling ignition.
thanks
