Component Enabled property Error on Button Pressed
this ticket is Resolved
Why did you clear your post? Now the topic makes no sense. You should revert your edit and instead add a new reply with how you resolved it to help others with a similar issue
Either that or delete it wholesale as now it will just pollute search results
Sorry mate i was planning to cancel the ticket but unable to find it....Why i close the ticket was i found the scripting is case sensitive and found the issue with one letter... this resolved the issue.
