Component Scripting - get only a certain type of component from getComponents()
I’d like to get a list of all the check boxes objects within a root container. Is there a way to test for component type?
win = system.gui.getWindow("Trending/ToolScreens/Trend")
template = win.getRootContainer().getComponent("TrendView").templates
comps = win.getRootContainer().getComponents()
tags = system.tag.browseTags(parentPath = "Trends/Tag History Pens")
param = "TagPath"
x = type(comps[0])
for comp in comps:
	print comp == x
from com.inductiveautomation.factorypmi.application.components import PMICheckBox
for comp in rootContainer.getComponents():
    if isinstance(comp, PMICheckBox):
        pass  # do something
Note that technically, you’ll want to call getComponents() recursively, and you also need to separate Vision “container-like” components from raw JComponents (all of which have a getComponents method).
Class names for the various default components are available here.
Thank you,
I did just get this to work:
for comp in comps:
if 'PMICheckBox' in str(x.getClass()):
