We are having this very issue on Ignition Version 8.42 in the Designer that property editor does not pop up. Did anyone find a solution? The Panel Reset option did not solve our issue
I am absolutely sure, as we are strictly working on the Vision system currently. We are trying to utilize the security feature on an individual window or just the root container of that window.
Sorry to revive a thread that hasn't been used recently, but I wanted to share what worked for me. Closing all of designer, deleting the cache, and starting it back up did not work. However, if I delete/rename the entire .ignition directory, that did work, though I'm not entirely sure why. I would recommend renaming so you can copy your settings back in.
However, with what happened while I was doing this I would recommend:
Close designer entirely
check if javaw or other ignition dependencies are still running - if they are, kill them.
I suspect the reason the cache clear didn't work was that something wasn't fully released.
now delete the cache folder, and relaunch designer
If this doesn't work, try renaming the entire ignition folder, and see if that fixes it.
Windows: %USERPROFILE%\.ignition
Linux and MacOS: ~/.ignition
