Components can only be moved by 10 spaces in designer
For some reason my components started to move by 10, and it does this for changing the size of the components too. If i change a components size it will round both x and y to the nearest multiple of 10, which is really annoying for designing layouts because I now have to type in the size of every component. It must be a key binding that I pressed accidentally maybe but I don’t know how to undo it. Can anyone help please.
Are you working in Vision?
Project → Project Properties → Vision → Design → Nudge Distance
I have the same setting but I’m still experiencing this problem. My coworker has the same settings as these also but he is not experiencing this issue
Restart the designer?
I have restarted many times, I have been working like this for the past month maybe so everyday I have restarted.
Look in the “View” menu for “Snap to Grid”. Shortcut is ^G.
It worked, thank you so much
