I’m having some strange Designer issues in Vision when dealing with components. I’m using version 8.1.1.
Not sure if this is normal, but it seems no matter what I select, the container (not sure if that’s the proper term in this case) is not centered with the component. Aside from the container not lining up with the shape, you can also see the arrows don’t line up as well.
Every now and then, this happens to components in a Vision window. If a new component is created within that window, it will have the same offset. If I copy and paste them into another window, it will look “normal” (as described in #1).
