This is what I am currently working with in the expression…
concat({Kimray Gas Meter/RTU/Month},"/",{Kimray Gas Meter/RTU/Day},"/",{Kimray Gas Meter/RTU/Year}," “,{Kimray Gas Meter/RTU/Hour},”:",{Kimray Gas Meter/RTU/Minutes},":",{Kimray Gas Meter/RTU/Seconds})
I’m assuming all your tags are integers, you may have to cast them to strings:
concat(toString({Kimray Gas Meter/RTU/Month}),"/",toString({Kimray Gas Meter/RTU/Day}),"/",toString({Kimray Gas Meter/RTU/Year})," ",toString({Kimray Gas Meter/RTU/Hour}),":",toString({Kimray Gas Meter/RTU/Minutes}),":",toString({Kimray Gas Meter/RTU/Seconds}))
I was curious about that too, but at least in the context of a memory tag integer, you don’t have to manually cast them as a string. maybe you do for an opc-ua tag, not sure. concat() or just the expression language does it for you in this instance.
