The configuration is suited to collecting and storing data, in a variety of DB formats. It has no support for client display and interaction, which I think is a tragic omission. But the Tag Historian and the SQL Bridge modules will store to a database in forms accessible to external applications. You simply connect that external application to the same database as Ignition. I personally prefer the SQL Bridge module for such duty, which I think will make sense when you have trained yourself to use it.
