Configure bindings with script
Is there any way we can configure bindings on a particular component through scripting.
Nope.
What do you want to do ?
I wish.
You could, by getting the view json with IgnitionGateway.get(), editing this json the way you want, and writing it back to the correct location.
Here is a code that should do the trick:
from com.inductiveautomation.ignition.gateway import IgnitionGateway
context = IgnitionGateway.get()
path = "%s/projects/YOURPROJECT/com.inductiveautomation.perspective/views/YOURVIEW/view.json"%(str(context.systemManager.dataDir.absoluteFile).replace('\\','/'))
json = system.file.readFileAsString(path)
data = system.util.jsonDecode(json)
#You edit the json here
new_json = system.util.jsonEncode(data)
system.file.writeFile(path, new_json)
Note that you'll have to wait a few minutes for the changes to be applied
What are you trying to accomplish?
