I apologize if the answer to this question is obvious but how do I configure a project so that the gateway gives me the option to start a it full screen, windowed, and/or as an applet?
I know how to do it with FPMI but can’t figure out how with Ignition.
Open up the project in the designer, click on the “Project” menu, select “Properties”, and under “Client” - “Launching” you will see check boxes for each launch option. You can also select the default launch mode.
