With beta6 and Twilio module up and running (account and key ok), I cant see how to use it in notification block. I can see and select all notification profile (voip, email, 2w email) but not sms…
Can you give me some direction…
regards,
regards,
There’s two steps for setting up the Twilio module in the gateway:
Under Twilio > Accounts, set up a Twilio account instance with your credentials. It sounds like you’ve done this already.
Under Alarming > Notification, add a “Twilio SMS Notification” profile and configure it to use the Twilio account set up in step 1.
Once you’ve created the notification profile you should be able to select it on the notification block in the designer.
Kevin,
Yes, obviously ! too obvious
