configureEditor on Power Table
I would like to display a list of parameters in a power table with 2 columns : Title and Value.
The values have different types, each has a render type and editor type :
  • boolean : JCheckbox
  • interger : JComboBox
  • string : JTextField
I manage to get the desired render with the "configureCell" function
However i can't get the same result with the "configureEditor" Function. It only allows to use one editor per column.
I guess it the event behind :
"jTable.getColumn("xx").setCellEditor(new DefaultCellEditor())"
I found an exemple on the web but i couldn't implement it.
Each Row with different Editor Example
Can someone please help me !!
Thank you.
Maxime.
Do you really need a table for this?
Perhaps you can come a long way with the template repeater. Just make a template that has a label on the left, and various input fields on the right. Show only the correct input field based on the data type, and make sure to pass everything via template parameters.
To get the values back, you can write it to a memory tag.
By adding borders, you can make it look like a real table. There are only a few things you’re missing, like f.e. resizing columns.
This is an example of what I made with the template repeater. The keys are for a label, and are extracted from a label template. The values are user-editable.
Maybe you are right. I hesitated with this solution.
However, I managed to do something nice with a power table.
I only have one problem left : i Have None in “newValue” in event “onCellEdit”.
My code for “configEditor”
 	from javax.swing import DefaultCellEditor
 	from javax.swing import DefaultComboBoxModel
 	from javax.swing import JTextField
 	from javax.swing import JComboBox
 	from javax.swing import JCheckBox
 	if colName == "val":
 		root = self
 		class CustomCellEditor(DefaultCellEditor):
 			def getTableCellEditorComponent(self, table, value, isSelected, row, column):
 				#get powertable.data
 				pydata = system.dataset.toPyDataSet(root.data)
 				#get type (in another column)
 				type = pydata[row]["type"]
 				#get column value
 				val = pydata[row]["val"]
 				#type boolean
 				if type == "boolean":
 					#cast string in bool
 					checkboxValue = val in ['true', '1', 'True']
 					dce = DefaultCellEditor(JCheckBox())
 					comp = dce.getTableCellEditorComponent(table, value, isSelected, row, column)
 					# set selected value
 					comp.setSelected(checkboxValue)
 					return comp
 				#type combo box
 				elif type == "combo":
 					dce = DefaultCellEditor(JComboBox())
 					dataFullText = []
 					#get powertable.options (custom property of power table, type : dataset, list of combobox options)
 					data = []
 					#code for make list of combobox options
 					comp.setModel(DefaultComboBoxModel(data))
 					selectedText = ""
 					#code for get item to select
 					#set selected value
 					comp.setSelectedItem(selectedText)
 					return comp
 		retour = CustomCellEditor(JComboBox())
 		return {'editor': retour}
I tried to rewrite the property getCellEditorValue () but without success.
I have an error : “getCellEditorValue() takes no arguments (1 given)”.
I think that in python there is a first argument, even if it is not declared : “self”
With “@staticmethod” it’s work better !!!
I managed to do what I wanted. I’m so happy !!
I’m trying to do exactly the same. Where are you putting @staticmethod to get newValue to return the edited value?
Finally I used a repeater template as sanderd17 said. It’s simpler, no need to master Java and more flexible.
It’s heavy and not perfect. There are problems during the validation, etc …
Otherwise here is the code with the static function:
	from javax.swing import JSpinner
	from javax.swing import SpinnerDateModel
	from java.util import Calendar
	from java.util import Date
	from javax.swing.BorderFactory import createEmptyBorder
	#on test si on est sur la colonne "val"
		#copie self dans une autre variable pour éviter la confusion.
		root = self
		#crée une classe hérité de DefaultCellEditor
			#On stock les pointeurs pour quand on va vouloir récupérer les valeurs.....
			#myJComboBox = CustomJComboBox()
			myJComboBox = JComboBox()
			myJCheckBox = JCheckBox()
			myJTextField = JTextField()
			#myJSpinner = JSpinner()
			#défini le nombre de clic pour editer la cellule....
			@staticmethod
			def isCellEditable(event):
				#test si double clic ou supérieur
				if event.getClickCount() >= 2:
					#si oui alors on edite
					return True
				else:
					#si non on édite pas.
					return False
			#méthode static sinon ca marche pas.
			@staticmethod
			def getCellEditorValue():		#on réécrit la méthode qui permet de récupérer la valeur d'édition.....(°°)
				result = "erreur"
				try:
					#on essaye de récupérer la
					if CustomCellEditor.myJComboBox is not None:
						result = CustomCellEditor.myJComboBox.getSelectedItem()
					elif CustomCellEditor.myJCheckBox is not None:
						result = CustomCellEditor.myJCheckBox.isSelected()
					elif CustomCellEditor.myJTextField is not None:
						result = CustomCellEditor.myJTextField.getText()
					elif CustomCellEditor.myJSpinner is not None:
						result = CustomCellEditor.myJSpinner.getValue();
					else:
						result = "rien de trouver"
				except Exception, e: print(e)
				#on renvoi la valeur récupérer : ouf !!!
				return result
			#redéfini la méthode "getTableCellEditorComponent"
				#on récupére le dataset
				#on récupère le type sous forme de string
				#on récupére la valeur
				#type boolean
					#récupère la valeur actuelle
					#init default cell editor of type JCheckBox()
					#recupère le pointeur vers getTableCellEditorComponent
					#set selected value
					#On set le fond à la même couleur que le reste de la ligne si sélectionné.
					comp.setBackground(root.selectionBackground)
					#on sauvegarde un pointeur vers cet objet pour en récupérer la valeur..... ca peut grave servir !!!!!
					CustomCellEditor.myJCheckBox = comp
					CustomCellEditor.myJComboBox = None
					CustomCellEditor.myJTextField = None
					#CustomCellEditor.myJSpinner = None
					#on renvoi le tout.
					return comp
				#Type text field
				elif type == "string":
					textValue = val
					dce = DefaultCellEditor(JTextField())
					#print dce
					#set selected value
					comp.setText(textValue)
					#On ne set pas le fond car pas lisible
					#comp.setBackground(root.selectionBackground)
					CustomCellEditor.myJCheckBox = None
					CustomCellEditor.myJTextField = comp
					#on renvoi le tout.
					return comp
				#type combo box
					#init default cell editor of type JComboBox()
					#init variable
					dataFullText = []
					#récupère pointeur vers dataset options (custom property objet power table)
					target = root.options
					#on récupère la liste à afficher sous forme de dataset mais sans les valeurs avant le signe =
					data = []
					#on récupère la liste pour la paramètre choisi
					ListText = root.ComboListText(target,root.data.getValueAt(row, 3))
					#on supprime les valeurs avant le signe égal.
					data = root.ComboListTextLight(ListText)
					#On set le model avec la nouvelle liste de donnée à afficher
					#On récupère la valeur à sélectionner
					selectedText = root.ComboTextFromInt(ListText, int(val))
					#set selected value
					#Set border
					comp.setBorder(createEmptyBorder())
					CustomCellEditor.myJComboBox = comp
					#on renvoi le tout.
					return comp
That worked a treat! Merci beaucoup.
