In my SQLTagProvider I am configuring a tag of type DateTime. When I view my tag in the designer, instead of seeing the date value, I see #,##0.## which is the Format String that has been set for that tag. When I edit the tag and set the format string to yyyy-MM-dd h:mm:ss aa then my datetime appears properly for my tag.
When configuring the tag in my TagProvider, how can I set that format string so that my DateTime values appear properly?
Strangely, it appears that that may not currently be possible. I think there should probably be an overload of configureTag and/or configureTagType that takes a set of default tag properties for the tag. In that case, you could just include the desired format string.
However, we probably should also default to a format string appropriate for the type of the tag…
Ah, you’re absolutely right… by doing that, you’re creating an “extension” for the tag, which will get applied on load. Don’t know why I didn’t think about that… it’s basically the same as going in the designer, editing the tag, and changing the format.
Anyhow, I will put the new version of configureTag in for 7.4, to make everything easier.
