Dear all,
I am testing Ignition 8.0.6 in a Linux Centos7 machi9ne. I have connected to a siemens LPC1500 successfully and now I am trying to manually specify each address following the documentation:
https://docs.inductiveautomation.com/display/DOC80/Siemens
The instructions say:
To manually specify each address
- From the Designer, in the Tag Browser , right-click on Tags folder, and then go to New Tag > OPC Tag .
- In the Tag Editor window, as an example, you can set the following values:
Data Type: Int4
OPC Server: choose Ignition OPC-UA Server with the edit button on the right.
OK, the OPC server cannot be selected. I select it while using the edit button on the right, and when I commit the change, this is not recognized, the corresponding field remains white and the selection is not recognized. Any idea of what am I doing wrong?
Thanks so much!
Patricia
