Connect Ignition to SCADAPhone alarm notification software
Hello! I am trying to connect Ignition to SCADAPhone which uses OPC DA. I have the OPC COM module installed but the OPC connection keeps faulting, with a fault of COM object method returns error code: 0:80080005; Server execution failed. Has anyone successfully connected Ignition to SCADAPhone? Thanks!
Given how much better other options for notifications are these days, I would be surprised if anyone has bothered attaching something that old to a new system. It is super affordable to use modern and well supported options for the same functions, and it will not be reliant on legacy systems.
One other thing is most likely your SCADAPhone software wants to be the client, not the server, and the Ignition OPC COM module is a client that tries to connect to an OPC-DA server, not the other way around. So most likely this won't work at all as you have planned.
While that may be true, my clients are slow to accept change. So allowing them to continue using an alarm notification software they are familiar with, I might actually be able to convince someone to switch from Wonderware to Ignition.
I think this is the answer here.
ScadaPhone - Most Reliable SCADA Alarm Notification Solution.
  • Configurable connection to any SCADA server that supports OPC, DDE, or OLE communications.
Natively it's not compatible so you'd need some middleware option like Matrikon OPC UA Wrapper or the Kepware equivalent.
Datasheet
Edit: Removed a bad suggestion
Between licensing costs and functionality alone you should be able to convince them. Every company using Wonderware that I give a demo to of our Ignition standard project has wanted to convert over. They're only holding themselves back by using antiquated software like Wonderware.
I spent a few days looking into this as a potential option for a client last year, and wasn't successful connecting the systems together. I would say that Michael, Kevin and Nol are on the right track about needing some sort of middleware.
Additionally, it was also a complete PITA to uninstall the SCADAPhone software from my laptop once I determined it wouldn't suit.I'm still not sure I ever got all of it out.
I agree with Dave, you're honestly better off using a more modern piece of software, that already works with Ignition. There are several modules, both IA and 3rd party, floating around that are designed to easily handle remote notification systems.
When you need overly verbose paragraphs of help text throughout your entire UI to explain what everything does, it’s probably a hint that your UI needs fixing… and if it still doesn't support opc-ua by now, well it’s clearly antiquated software… that’s my 2c on scada phone :grimacing:
