Connect modbus device to ignition which deploy on VM
hello, I have a modbus device that connect to my local laptop. I have an Ignition deplyed on VM and want to connect the modbus device to the ignition gateway via Device Connections. However, it failed and I think there maybe some routings need to be done between the local laptop and the Ignition VM. Any thinking on what shoud I do? Also I confirm that the modbus device can connect to the loca hosted igniton.
Probably so, but you have not given any onformation on how the network is set up on the eithr VM or on the device.
