Hello guys,
I’m trying to connect to a MySQL database from Ignition.
I granted the root with full privileges, selected de right driver for MySQL(jdbc driver) in Ignition Gateway and after I save the configuration the connection status is “faulted”.
Bellow you can see the erros showing and the configuration of db connection in Ignition.
Thank you in advance for the support!
