I was wondering, is it possible to connect to a database server, in my case MySql, using script or ignition designer property without defining the connection in the gateway connections?
You can connect to a database by setting it up as a datasource via scripting:
I would hazard a guess that this would not work in an Edge gateway as there are restrictions edge's database connections
Well this is the exact thing i was looking for, but it is the half solution, can we also remove the data source that was added via scripting?
Oh yes we can.
system.db.removeDatasource(name)
