I’m trying to connect to a B&R Embedded OPC-UA Server.
I can connect to it with other OPC Clients from the same PC but not with Ignition.
Any help appreciated.
I have added it as an OPC Server Connection with the following settings:
Host: opc.tcp://172.16.211.127
Port: 4840
Security Policy: Basic128Rsa15
Message Security Mode: SignAndEncrypt
Username: admin
Password: password
I know these settings are correct as they work with the other OPC clients.
There may be a problem with certificates though. I can’t find much information on these and the other clients I am using both require to Trust the OPC Servers certificate. I cannot find how to do this in Ignition.
The error I’m getting in the OPC Servers Connection Status is:
com.inductiveautomation.opcua.UAException: null
com.inductiveautomation.xopc.client.stack.TCPClientChannel.getAddress(TCPClientChannel.java:541)
com.inductiveautomation.xopc.client.stack.TCPClientChannel.open(TCPClientChannel.java:227)
com.inductiveautomation.xopc.client.stack.TCPClientChannel.getEndpoints(TCPClientChannel.java:84)
com.inductiveautomation.xopc.client.stack.TCPClientChannel.getEndpoints(TCPClientChannel.java:72)
com.inductiveautomation.xopc.client.util.ConnectionUtil.getEndpoint(ConnectionUtil.java:64)
com.inductiveautomation.xopc.client.OpcUaConnection.createUaClient(OpcUaConnection.java:523)
com.inductiveautomation.xopc.client.OpcUaConnection.verifyConnectionState(OpcUaConnection.java:141)
com.inductiveautomation.xopc.client.FailoverAwareOpcUaConnection.verifyConnectionState(FailoverAwareOpcUaConnection.java:75)
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$ServerWrapper.verifyConnectionState(OPCManagerImpl.java:742)
com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$OPCConnectionKeepalive.run(OPCManagerImpl.java:618)
com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:573)
java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
java.util.concurrent.FutureTask.runAndReset(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
Does anybody know what this means?
Any ideas on what I can try?
David
