Connecting 4 plcs from 4 different cities to a single ignition gateway
I and my team have converted 4 Raspberry pi’s into PLC’s and these devices are in 4 different locations. The process for one Raspberry pi is coded in ladder logic using codesys and connected to ignition through opc ua. Now i need to connect all these devices which are in different cities or get the tags from all these 4 devices from different cities to a single ignition gateway. Can anyone please help me with this?
Thank you in Advance
It’s a newer project, but since you’re using codesys, you might want to look at this instead of OPC UA:
https://forge.codesys.com/prj/mqttsparkplugb/home/Home/
Thank you
