Connecting Arduino communicating in OPC to Ignition SCADA
Has anyone tried to connect an Arduino to ignition scada through OPCDA ?
Arduino is connected through a serial port and I have Arduino OPC server already installed and functioning as well as output parameters can be read by external sources OPC client/explorer applications.
However, when I try to connect to the OPC server from the gateway (opc connections - opc da connection) it displays connecting and does not connect .
Is there any further configurations that I should go through?
Here is the code of the Arduino:
#include <OPC.h>
// declare opc object
OPCSerial aOPCSerial;
// declare pins that will be in use
int ledPin = 7;
int buttonPin = 2;
int analogPin = 0;
char ledState = 0;
// callback function
int callback1(const char *itemID, const opcOperation opcOP, const int value){
  static int ledValue = ledState;
  if (!strcmp(itemID,"led"))
    // if a write
    if (opcOP == opc_opwrite) {
      /*ledValue = ledState;*/
      if (ledValue)
        digitalWrite(ledPin, HIGH);
      else
        digitalWrite(ledPin, LOW);
    else
       * read the led status
      return ledValue;
  if (!strcmp(itemID,"button"))
    return digitalRead(buttonPin);
int callback2(const char *itemID, const opcOperation opcOP, const int value){
  if (!strcmp(itemID,"analog0"))
    return analogRead(analogPin);
void setup() {
  Serial.begin(9600);   // serial comms
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, OUTPUT);
  aOPCSerial.setup();   // opc init
  // declare items
  aOPCSerial.addItem("led", opc_readwrite, opc_bool, callback1);
  aOPCSerial.addItem("button", opc_read, opc_bool, callback1);
  aOPCSerial.addItem("analog0",opc_read, opc_int, callback2);
void loop() {
  // Read the analog value from A0
  int analogValue = analogRead(analogPin);
  // If the analog value is less than 500, turn on the pump
  if (analogValue < 500) {
    digitalWrite(buttonPin, HIGH); // turn on the pump
    ledState = 1;
  } else {
    digitalWrite(buttonPin, LOW); // turn off the pump
    ledState = 0;
  // start processing of opc commands
  aOPCSerial.processOPCCommands();
Please format the code.
  • Hit the 🖉 edit button below your post.
  • Select the code.
  • Press the </> button on the editor toolbar. It's a formatting button so it works the same as the B or I buttons. It will preserve indentation and apply syntax highlighting.
I assume you’re using this library…
…which appears to be written by someone who has absolutely no idea what “OPC” is and has completely mis-used the term to describe some made up data sharing scheme he invented.
Try finding a Modbus library for Arduino instead?
