Okay I have this Vendor Device from FOSS/ProcessScan2. It has an option to connect to an OPC UA Server, from my understanding from that server its expecting to have pre-defined opc paths/string node ID's. The purpose of this being to transfer data from the FOSS to ignition. Is it possible to directly connect this client to ignition and read those tags? I have adjusted the OPC Server settings on ignition and it says connected, but I'm not sure how I would read or map these specific tags. I'm running a simulator and ignition on my local host
