Connecting LK-G5001 to Ignition SCADA via EtherNet/IP
We are planning to connect the LK-G5001 sensor to our Ignition SCADA system. As the sensor supports EtherNet/IP communication, we would like to know if it is possible to read the controller values and display them directly in Ignition.
Currently, we do not have a Keyence-specific EtherNet/IP driver in Ignition. Could you please advise:
  1. What drivers are required to establish communication between the LK-G5001 and Ignition SCADA?
    AS_53408_LK-G5000_UM_96M12277_WW_GB_1116_6 (2).pdf (6.7 MB)
This is what you'll probably need:
Yes, my driver's scanner+adapter option is required for these. And for most Keyence devices--they all use a common pattern in their I/O buffers, with minor per-model tweaks. Send the EDS file and the PDF user manual to my sales email address and I'll see what this model needs.
