I know, ENIs suck… That said, I am trying to connect to a ML1500 through an ENI. When I connect using RSLinx everything works and I am turning off the connection from RSLinx while trying to connect using Ignition so I don’t hit a connection limit.
If I leave the connection path blank the status stays at Connecting: Protocol: EIP. If I put anything into the path is stays at Connecting: Protocol: Bridged_EIP.
Yep… unfortunately this means you nothing will show up when you go to browse the device in the OPC browser - you’ll have to manually create and address SQLTags instead of drag n’ dropping them.
