Connecting to adhoc SQLite database from Jython?
Has anyone successfully connected to an adhoc SQLite database before in Jython? I would normally use the sqlite3 library but it’s C-based. I only want to connect to it briefly to pull out some config.
If you must know, I want to connect to the Ignition config.idb to export some tables to JSON format so that I can document configuration and also compare config between gateway, so I want to get in and out.
Otherwise, would creating a connection to it via the gateway config cause issues? I would keep it disabled until I needed it after which I would disabled it again.
You can’t make additional connections to the config.idb (open the file) while Ignition is running.
Well that sounds slightly prohibitive then for what I’m doing :slight_smile: Also I’m sure I knew that already… I’ll have to go to plan B and copy the db or use a gateway backup’s copy instead and I’ll connect to it via the gateway config method. Cheers
Use the SDK APIs. If you can get a GatewayContext, you can call GatewayContext::getLocalDBInterface and then run queries on it. Danger zone.
https://files.inductiveautomation.com/sdk/javadoc/ignition81/8.1.11/com/inductiveautomation/ignition/gateway/localdb/DBInterface.html#runQuery(java.lang.String)
Is there any danger in running SELECT * queries on a few small tables (SYSPROPS/DEVICESETTINGS/ others, NOT any tags tables)?
Should be okay… :grimacing:
You can also poke around from http://localhost:8088/web/status/sys.internaldb
Cheers, I saw that on the forum a year or so ago but I never actually tried it out. I need to get the results into python though so will be easier to query in script. We have a test environment, so here goes!
Hmm, I’m getting an error trying to run runQuery:
SQLFeatureNotSupportedException: java.sql.SQLFeatureNotSupportedException
	from com.inductiveautomation.ignition.gateway import IgnitionGateway
	import traceback
	context = IgnitionGateway.get()
	dbi = context.getLocalDBInterface()
	try:
		rs = dbi.runQuery('SELECT * FROM SYSPROPS')
	except:
		err = traceback.format_exc()
		system.tag.writeBlocking('[.]test', err)
I’m running it for testing from a tag change script. Tag is a memory bool tag that I just toggle to execute it
Hmm. I don’t know why that doesn’t work… maybe I lead you down the wrong path :sweat:
session = IgnitionGateway.get().getPersistenceInterface().getSession()
try:
    session.rawQueryMaps("SELECT * FROM SYSPROPS")
finally:
    session.close()
You could try this; see SSessionJdbc. Make very sure you close the session, or this will hose a running gateway until restarted.
Would a context manager work here to close the session for me?
with session.rawQueryMaps('...') as rs:
   #stuff
   pass
session is an AutoCloseable, which in Java means you can use try-with-resources for the same basic pattern as a context manager. Unfortunately, I think Jython predates try-with-resources, and there’s no ready-made context manager… although contextlib.closing may ‘just work’, since the method is just called close()?
https://docs.python.org/2.7/library/contextlib.html#contextlib.closing
So it would be with contextlib.closing(persistenceInterface.getSession()) as session:, then the rawQueryMaps call inside the block.
This worked, I need to provide the other 2 args though:
try:
    session.rawQueryMaps("SELECT * FROM SYSPROPS", True, []) # sql, flush, params
finally:
    session.close()
Not entirely sure what flush does…
Flush should be pretty much irrelevant to a select…
