I am new to Ignition and I am trying to connect to an allen bradley compactlogix l33er.
When putting in the IP address I get connected, but when looking at the log I have the following errors,
| LogixBrowseStateManager |
03Nov2023 09:10:12 |
Browse failed: EtherNet/IP status: INVALID_UNSUPPORTED |
| ReadBrowseHashRequest |
03Nov2023 09:10:09 |
Error reading browse hash: EtherNet/IP status: INVALID_UNSUPPORTED |
| LogixDriver |
03Nov2023 09:10:08 |
Thanks in advance
What firmware version are you using? Logix driver is only for v21+
Hi Hayden,
I currently am waiting for the software to be installed so I can log in to see what driver is on the PLC as i am new to the site and am still waiting for all my kit.
The plc was programmed in 2013 last i dont know if that could gave any indication?
It performs best with v21+, it works with older versions though.
@Alex_Evans this looks similar to errors when people configure the driver but point it at something that isn't a Logix PLC. You probably have the wrong IP address or the wrong slot number. Finding out the firmware version would still be useful though.
Hi, I am presenting the same issue. I can´t connect to a Allen Bradley CompactLogix L24ER, but I never get the device to get "connected". The firmware version is 34. I even tried using the "Allen-Bradley Logix Driver"
Are there any errors in your gateway logs? Can you ping the PLC from your gateway machine? (not your own laptop, the actual device with the gateway). You will need to validate that your gateway device can reach your PLC. You may need to adjust firewall settings on your gateway device to allow traffic on port 44818(default E/IP port)
