Connecting to MSSQL server with a linked server
Hello, I'm trying to connect to a MSSQL server which is connected to our ERP system.
Since our ERP uses ODBC for connection I've set up a linked server in SSMS which works fine, although when I'm trying to run a query Ignition returns error -155.
Error from Designer:
Error running query: SELECT * FROM OPENQUERY([Server], 'SELECT * FROM [schema].[table]') WHERE status = 3 Unknown SQL type: -155
There is something in that linked server that is using a column type that your MS JDBC driver doesn't support. Are you using the latest JDBC driver for your java/sql server combination?
I'm running Ignition 8.1.4, with the JDBC driver 9.4.0. Would an upgrade possibly resolve the issue?
Maybe, but be aware that upgrading Ignition doesn't upgrade the JDBC driver. That would be a separate operation (that you can do now).
I tried updating the driver to the latest file from MS (12.8.1.0 java 11), but that resulted in an connection error to the database, so I had to go back to the original. Is there a way to set up a new database connection directly to my linked server?
Instead of doing a SELECT * list your columns and CAST the problematic column.
THIS WORKS!!! Thank you very much :smile:
If you're querying data from linked servers in MSSQL I would recommend putting your queries in stored procedures so future JDBC driver changes can't impact functionality.
