Connecting to mySQL 4.0.26 Cannot create PoolableConnectionFactory (ResultSet is from UPDATE. No Data.)
I am struggling to get a valid connection to a MySQL database. The SQL database is hosted on a machine which is remote from the Ignition server. I have set up a user in PHPMyAdmin with any host and global privileges. I have also turned the firewall off to see if that was blocking me. I read that MySQL 4.x is not fully supported but I should be able to connect. Does anyone have any advice?
java.sql.SQLException: Cannot create PoolableConnectionFactory (ResultSet is from UPDATE. No Data.)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2385)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2110)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1563)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:257)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:211)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1016)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:565)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: java.sql.SQLException: ResultSet is from UPDATE. No Data.
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1074)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:988)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:974)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:919)
at com.mysql.jdbc.ResultSetImpl.next(ResultSetImpl.java:6999)
at com.mysql.jdbc.ConnectionImpl.loadServerVariables(ConnectionImpl.java:4141)
at com.mysql.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:3548)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2513)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2283)
at com.mysql.jdbc.ConnectionImpl.(ConnectionImpl.java:822)
at com.mysql.jdbc.JDBC4Connection.(JDBC4Connection.java:47)
at jdk.internal.reflect.GeneratedConstructorAccessor82.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:404)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:317)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:53)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:291)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2395)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2381)
… 12 m
What version of Ignition are you using and what version of the MySQL JDBC driver is installed?
V 8.0.2. I have looked at the MySQL drivers in Database>Drivers but i can’t see what version I am using
any ideas?
Sorted! i tried an old MySQL connector 5.1.48 and managed to get it to work.
