Hello guys,
We are trying to connect to ProConOS OPC Server 2.1 by KW-Software GmbH
We are using OPC-DA type of connection. The status is always “Connecting”.
What is going on?
Hello guys,
What is going on?
On logs, we got the following error:
com.jniwrapper.win32.com.ComException: COM object method returns error code: 0x80080005; Server execution failed
at com.jniwrapper.win32.com.ComException.checkResult(SourceFile:172)
at com.jniwrapper.win32.com.ComFunctions.coCreateInstanceEx(SourceFile:230)
at com.inductiveautomation.opccom.COMServerImpl$ConnectServerJob.internalRun(COMServerImpl.java:703)
at com.inductiveautomation.opccom.wrapper.OleJob.run(OleJob.java:48)
at com.jniwrapper.win32.MessageLoopThread$ThreadSynchronizedAction.run(MessageLoopThread.java:620)
at com.jniwrapper.win32.MessageLoopThread$LoopThread.run(MessageLoopThread.java:562)
Hello,
Is your connection allready up?
I have the same issue, can’t get the ProConos OPC connection running.
If it is working on your side, can you please tell me the settings for this connection?
Regards,
Werner
Hello,
Yes, we managed to connect.
It turns out that we were neded to configure DCOM settings (ODMV3) for our OPC server. Guys told me that both Ignition server and ODMV3 (Online-Data-Manager Version 3) needed to be started with the same user.
