Connection Error gateway network - Abruptly closed by peer
Hello,
i'm trying to connect 2 gateway in 2 different VM.
When i connect the gateway network i have this error:
-> outgoing local='ignition-xxxxx400' remote='https://xx.xxx.xxx.167:8060/system' method=handleConnectException: Connection attempt to wss://xx.xxx.xxx.124:8060/system/ws-control-servlet?name=ignition-xxxxx400&uuid=a244a523-23b2-4532-4534-d74abc62e3a0&url=https://xx.x.xx.45:8060/system failed! Error message=Abruptly closed by peer
I opened the port correctly
If i use the connection without SSL with port 8088 the connection work correctly.
Maybe is an error of certificates? What i must check?
Thank you so much for the help
You probably have a higher rule in the firewall that blocks SSL for you, even though you have the port enabled
