Connection pooling
How does connection pooling work? I leave most of the parameters at the default, so Initial size = 0, Max active = 8, Max idle = 8, and Test while idle = unchecked. If I understand correctly, Ignition will open up to 8 connections to the database, as needed, and never close them? Then a connection would get removed from the pool if it failed validation when it’s picked up the next time?
I’ve got 14 database connections set up, so that’s a possible 112 database connections. Ignition 7.8.x, Oracle, Linux 64-bit.
We ran into an issue today and I’m told this isn’t really a problem, but I’d like to understand how it works.
Hello,
Your assessment is correct.
Ignition uses Apache Commons DBCP for its database pooling. Here is some examples and documentation on the subject:
http://www.tomcatexpert.com/blog/2010/04/01/configuring-jdbc-pool-high-concurrency
https://commons.apache.org/proper/commons-dbcp/configuration.html
