Hello,
I have a probleme to connect to Ignition OPC UA server with UA expert, is not working despite that I add put on Security settings of opc ua server on ignition, I didnt'find problem ,
someone have a idea?
Many thanks for yours helps!
Eric
------Message error in Ignition---------------
| UascServerAsymmetricHandler | 28Dec2023 19:45:35 | Error installing security token: StatusCode{name=Bad_SecurityChecksFailed, value=0x80130000, quality=bad} |
| org.eclipse.milo.opcua.stack.core.UaException: no matching endpoint found: transportProfile=TCP_UASC_UABINARY, endpointUrl=opc.tcp://localhost:62541/discovery, securityPolicy=Basic256Sha256, securityMode=SignAndEncrypt | ||
| at org.eclipse.milo.opcua.stack.server.transport.uasc.UascServerAsymmetricHandler.lambda$openSecureChannel$3(UascServerAsymmetricHandler.java:410) | ||
| at java.base/java.util.Optional.orElseThrow(Unknown Source) | ||
| at org.eclipse.milo.opcua.stack.server.transport.uasc.UascServerAsymmetricHandler.openSecureChannel(UascServerAsymmetricHandler.java:400) | ||
| at org.eclipse.milo.opcua.stack.server.transport.uasc.UascServerAsymmetricHandler.lambda$sendOpenSecureChannelResponse$1(UascServerAsymmetricHandler.java:311) | ||
| at org.eclipse.milo.opcua.stack.core.channel.SerializationQueue.lambda$encode$0(SerializationQueue.java:59) | ||
| at org.eclipse.milo.opcua.stack.core.util.TaskQueue$TaskWrapper.run(TaskQueue.java:273) | ||
| at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) | ||
| at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) | ||
| at java.base/java.lang.Thread.run(Unknown Source) |
