Hey all,
I am trying to connect a CrateDB instance to my Ignition SCADA.
- I have downloaded the JAR file (crate-jdbc-2.6.0 jar) while following the instructions here (Crate Connect Manual JDBC )
- Then Went to the Gateway config page and added new JDBC driver and added the JAR file from above using Postgres as the default translator.
3. After that I went and added new connection using the CrateDB driver using the default settings from the instruction above (i.e. crate://localhost:5432/ and user crate with no password.
Finally all I got is that the Connection is showing as “Connecting” and stays there. I can see and query the DB using the browser page so I know that the DB is functioning correctly.
Is there anything obvious that I am getting wrong here?
Thanks in advance!
