Hi, I have this very long query wherein i do
[code]SET @location = ‘2/12 Influent Wells - EW-12-05-180-M’;
SELECT @location AS LOCATION,
ROUND(sum(CASE WHEN t2.tagid = ‘2874’ THEN t2.floatvalue ELSE 0 END), 2) AS Meter_Reading,
ROUND(sum(CASE WHEN t2.tagid = ‘2734’ THEN t2.floatvalue ELSE 0 END), 2) AS GPM,
ROUND(sum(CASE WHEN t2.tagid = ‘2735’ THEN t2.floatvalue ELSE 0 END), 2) AS PSI,
ROUND(sum(CASE WHEN t2.tagid = ‘2736’ THEN t2.floatvalue ELSE 0 END), 2) AS DTW
FROM sqlt_data_2_2013_11 t2
INNER JOIN sqlth_te t1
ON t1.id = t2.tagid
WHERE t2.t_stamp = (SELECT MAX(t2.t_stamp)
WHERE t1.id = t2.tagid)
UNION ALL
SELECT ‘aes/fortord/site 12 slc/ew 12 06 180m/fiq’ AS LOCATION, /EW-12-06-180-M/
ROUND(sum(CASE WHEN t2.tagid = ‘2876’ THEN t2.floatvalue ELSE 0 END), 2) AS Meter_Reading,
ROUND(sum(CASE WHEN t2.tagid = ‘2743’ THEN t2.floatvalue ELSE 0 END), 2) AS GPM,
ROUND(sum(CASE WHEN t2.tagid = ‘2744’ THEN t2.floatvalue ELSE 0 END), 2) AS PSI,
ROUND(sum(CASE WHEN t2.tagid = ‘2742’ THEN t2.floatvalue ELSE 0 END), 2) AS DTW
ON t1.id = t2.tagid
UNION ALL [/code]
I’ve noticed that since I started that sql query my connection to the gateway on the designer keeps disconnecting then connects back again and again.
Could it be because of this? Could it be something like query overload can that happen?
