Hello!
I’ve been having troubles with modbus connection. Ignition gets disconnected from the PLC. The connection is through modbus and the only way I have to restore the connection is restarting the Ignition service. This happens since I installed Ignition 7.3.
Here are the logs:
INFO | jvm 3 | 2012/04/11 18:42:07 | WARN [TCPClientChannel ] [18:42:07,916]: Connection lost.
INFO | jvm 3 | 2012/04/11 18:42:07 | java.net.SocketException: Connection reset
INFO | jvm 3 | 2012/04/11 18:42:07 | at java.net.SocketInputStream.read(Unknown Source)
INFO | jvm 3 | 2012/04/11 18:42:07 | at com.inductiveautomation.common.iosession.socket.AsyncSocketIOSession.run(AsyncSocketIOSession.java:92)
INFO | jvm 3 | 2012/04/11 18:42:07 | at java.lang.Thread.run(Unknown Source)
INFO | jvm 3 | 2012/04/11 18:42:07 | WARN [TCPServerChannel ] [18:42:07,916]: Connection lost due to IOException.
INFO | jvm 3 | 2012/04/11 18:42:08 | ERROR [WriteCall ] [18:42:08,604]: Call failed client-side with StatusCode: StatusCode[0x808A0000, Severity=Bad, Subcode=Bad_NotConnected]. Cannot send a message while channel is in state: CLOSED
INFO | jvm 3 | 2012/04/11 18:42:08 | ERROR [Provider[default] ] [18:42:08,604]: [[default]PLC2MW/R1MarchaRecirculacionInterna] Error writing to OPC address [[Ignition OPC-UA Server][PLC2]1.MW2_52]. Result code: Not Connected
INFO | jvm 3 | 2012/04/11 18:42:08 | ERROR [Provider[default] ] [18:42:08,604]: [[default]PLC2MW/R1Forzados] Error writing to OPC address [[Ignition OPC-UA Server][PLC2]1.MW2_58]. Result code: Not Connected
INFO | jvm 3 | 2012/04/11 18:42:08 | ERROR [Provider[default] ] [18:42:08,604]: [[default]PLC2MW/R1VariadorSoplanteFreq] Error writing to OPC address [[Ignition OPC-UA Server][PLC2]1.MW2_53]. Result code: Not Connected
INFO | jvm 3 | 2012/04/11 18:42:09 | ERROR [WriteCall ] [18:42:09,604]: Call failed client-side with StatusCode: StatusCode[0x808A0000, Severity=Bad, Subcode=Bad_NotConnected]. Cannot send a message while channel is in state: CLOSED
INFO | jvm 3 | 2012/04/11 18:42:09 | ERROR [Provider[default] ] [18:42:09,604]: [[default]PLC2MW/R1ValvulaAeracionA] Error writing to OPC address [[Ignition OPC-UA Server][PLC2]1.MW2_56]. Result code: Not Connected
INFO | jvm 3 | 2012/04/11 18:42:09 | ERROR [Provider[default] ] [18:42:09,604]: [[default]PLC2MW/R1ValvulaAeracionB] Error writing to OPC address [[Ignition OPC-UA Server][PLC2]1.MW2_57]. Result code: Not Connected
INFO | jvm 3 | 2012/04/11 18:42:09 | ERROR [Provider[default] ] [18:42:09,604]: [[default]PLC2MW/R1Forzados] Error writing to OPC address [[Ignition OPC-UA Server][PLC2]1.MW2_58]. Result code: Not Connected
INFO | jvm 3 | 2012/04/11 18:42:09 | ERROR [Provider[default] ] [18:42:09,604]: [[default]PLC2MW/R1VariadorSoplanteFreq] Error writing to OPC address [[Ignition OPC-UA Server][PLC2]1.MW2_53]. Result code: Not Connected
INFO | jvm 3 | 2012/04/11 18:42:09 | ERROR [Provider[default] ] [18:42:09,604]: [[default]PLC2MW/R1MarchaRecirculacionInterna] Error writing to OPC address [[Ignition OPC-UA Server][PLC2]1.MW2_52]. Result code: Not Connected
INFO | jvm 3 | 2012/04/11 18:42:09 | INFO [CaudalDiarioRecirculacionInternaA] [18:42:09,729]: Trigger did not evaluate - source item currently has bad quality [[55,Not Connected]].
INFO | jvm 3 | 2012/04/11 18:42:09 | INFO [CaudalDiarioRecirculacionInternaB] [18:42:09,729]: Trigger did not evaluate - source item currently has bad quality [[55,Not Connected]].
INFO | jvm 3 | 2012/04/11 18:42:10 | ERROR [WriteCall ] [18:42:10,604]: Call failed client-side with StatusCode: StatusCode[0x808A0000, Severity=Bad, Subcode=Bad_NotConnected]. Cannot send a message while channel is in state: CLOSED
How can I fix this?
Thanks for your help!
