[quote=“Curlyandshemp”][quote=“drewdin”]I am running Version 7.6.4 and I ran into this same exact issue. I needed to restart OPC-UA as stated in this post and it fixed it. Has this not been fixed yet I take it?
Thanks[/quote]
Since upgrading to V7.6.6 I have not seen this issue , as I too experienced.
BUT, in V7.6.6 the export of UDT tags is broken. This has been acknowledged by Tech Support.
You have to export all the tags and strip out the UDT tags from the .xml or .csv file.[/quote]
Take it back, just had new complex UDT added to Compactlogix PLC V20 running Ignition V7.6.6 and tags appeared as folders:
[attachment=1]ScreenHunter_187 May. 21 19.16.jpg[/attachment]
toggle disable/enable and appeared ok:
[attachment=0]ScreenHunter_188 May. 21 19.18.jpg[/attachment]
