[color=#0000FF][color=#0000FF][/color][/color]Hi,
I neet to convert Int to BCD Data. I found a python library bcd 0.4.( check the link) pypi.python.org/pypi/bcd/0.4
Is that possible to download this library in Ignition? How can I do that?
If not, there is any code that someone is using to convert bin, hex, and decimal to BCD???
Regards,
You can take advantage of the fact that BCD is encoded the same as those digits in hexadecimal. So printing the bcd register (an integer) as hex will display it correctly. Converting that hex string as if it is decimal then gives you the normal integer. Some examples:[code]Jython 2.5.3 (, Sep 23 2013, 00:05:54)
[Java HotSpot(TM) 64-Bit Server VM (Oracle Corporation)] on java1.8.0_92
Type "help", "copyright", "credits" or "license" for more information.
bcd = 0x456
bcd
1110
hex(bcd)
'0x456'
'%x' % bcd
'456'
decimal = int('%x' % bcd)
decimal
456
bcd2 = int(str(decimal), 16)
bcd2
1110
hex(bcd2)
'0x456'
[/code]
I’m sorry but I can’t understand.
I need to write a decimal value. Example. 14.
this number in BCD means 0001 0100. Every decimal digit means four bits.
Example: Decimal 1 = BCD 0001
Decimal 4 = BCD 0100
I need a code to make that convertion. I have no idea how to building this code…Sorry but I’m not a deep python or Java programmer.
Regards,
Leandro
EDIT: Phil already covered this in his post with:
bcd = int(str(decimal), 16)
a much shorter method…
This is one I wrote a while back:
def dec2BCD(inputValue):
x=str(inputValue)
BCDOut = 0
for char in x:
BCDOut = (BCDOut << 4) + int(char)
return BCDOut
