Convert Json String to PyObject
I am a bit lost in sdk about json.
I have a json string I need to convert to PyObject for the result returned by a script function in a module.
What is the best way to achieve this with the sdk ?
org.json.JSONObject() return JSONObject ?
But I don’t fin any class to manipule it ?
com.inductiveautomation.ignition.common.TypeUtilities with gsonToPy need JsonElement ?
com.inductiveautomation.ignition.common.JsonUtilities ?
You can probably just call SystemUtilities.jsonDecode if you want the exact same behavior as the scripting function.
Perfect ! I was quite sure there was something built-in in the sdk.
