Convert return format query to DOCUMENT type
Good morning,
I’m using Apex Chart to show data and I have some problems trying to populate data series with a query.
If I use a Tag History I’m able to show it selecting the tag, setting to Value Format to “DOCUMENT” and add a configure trasform for having as result t_stamp as 0 index and tag_name as 1 index.
Annotation 2022-08-12 112932
The “problem” is that if I bind the data property to a Query I’m not able to select DOCUMENT as Return format.
Is there any way to convert a dataset to a document and have the same result as with Tag History?
Thank you for the help
Have you tried using the json format?
return [[row['t_stamp'], row['otherColumn']] for row in system.util.jsonDecode(value)]
Thanks for the reply… I’ve just tried, but it returns this error:
TypeError: jsonDecode(): 1st arg can’t be coerced to String
Force the value to a string type.
return [[row['t_stamp'], row['otherColumn']] for row in system.util.jsonDecode(str(value))]
Document and JSON return format should be equivalent; I don’t think you need to manually encode or decode, or at least you shouldn’t.
I don’t know what I was looking at, you are right because actually the chart works good with JSON return format, I do apologize with all of you for the mistake.
