Convert standard license to leased license
Hello, we are migrating an Ignition Gateway from VMs to K8S. So now they will be running inside containers.
Is there any way how to convert the standard license to a leased license that is recommended way to be used with containers?
Or we can use the standard license and use this runtime argument, which will unactivate the license?
-Dignition.license.leased-activation-terminate-sessions-on-shutdown=true
If it is possible how to pass the license key? can we use IGNITION_LICENSE_KEY parameter to se it up?
Thank you in advance
You'll have to contact your sales rep to convert your license to an 8-digit version. That system property as well as the IGNITION_LICENSE_KEY and IGNITION_ACTIVATION_TOKEN environment variables only work with the 8-digit leased activation licensing.
Great thank you for the quick response. So it is possible to do that?
and one more thing where can I find our sales rep? is it mentioned under the licensing page? thx
If you're unsure, the easiest path might be to get in touch with support.
Thank you
