Convert timestamp to datetime
Hi there is there anyway to convert the timestamp to a datetime?
I have a table with datetime column (sql query) in it and I want to pass the value with payload when click on the table row to a datepicker. It passes the datetime but in a timestamp format…
but I want it to be
You could do this through scripting I’m sure, but you could also pass the value to a placeholder property (key in my example), then bind a property (probably DateTimeInput.props.value) to the placeholder and apply a Format transform.
You could also try this:
from datetime import datetime
return datetime.fromtimestamp(value/1000)
where value is the t_stamp value. This works for me when attempting to convert a t_stamp (big int) column from a MySQL table.
Eschew Python’s datetime - use system.date.parse or system.date.fromMillis to construct Java Date objects.
Just to add onto @paul-griffith’s response, using Java Date Objects lets you use system.db.runPrepUpdate and not have to do any further date/string manipulation, which is very helpful.
Thanks guys for the solutions :+1:
Learnt something new :smiley:
