Convert to dataset
Hi Friends,
I’m trying to convert data into a dataset using toPyDataSet.
val1 = system.tag.readBlocking([’[default]Sample/Tag 1/tag’])[0].value
val2 = system.tag.readBlocking([’[default]Sample/Tag 2/tag’])[0].value
data =
data.append(val1)
data.append(val2)
convertData = system.dataset.toPyDataSet(data)
print(convertData)
found the error → TypeError: toPyDataSet(): 1st arg can’t be coerced to com.inductiveautomation.ignition.common.Dataset
Please can you suggest what is wrong from my side as soon as possible?
Thanks,
Priyanka
Hi, @victordcq can you suggest any solution?
val1 and val2 are just single values correct?
You first need to make a dataset before you can go to pydataset.
To turn it into a dataset, you need an array of headers and an array of values per row. check here:
https://docs.inductiveautomation.com/display/DOC81/Datasets
Yes. val1 and val2 get single integer value from tag.
check out the link it should explain everything^^
data =
data.append(val1)
data.append(val2)
ds = system.dataset.toDataSet(data)
convertData = system.dataset.toPyDataSet(ds)
print(convertData)
Added dataset still found same error.
needs two arguments, the first is the headers, the second the values
Yes. Added headers also but still not working.
headers = [‘Sample’]
data =
data.append(val1)
data.append(val2)
ds = system.dataset.toDataSet(headers,data)
print(convertData)
what is the error?
Screenshot (84)
ah yes each row needs to be in its own array.
so in your case
data.append([val1])
data.append([val2])
Hi @Priyanka.Khandge, I think @victordcq has answered the primary question, but I was just wondering why why your data has to be a dataset or PyDataSet?
Hi, @victordcq Thank you for the neat step by step explanation.
As a side note, if you have many tags, it will be more efficient to read the tags all at once, then use a loop to construct your dataset.
tagList = ['[default]Sample/Tag 1/tag',
           '[default]Sample/Tag 2/tag'
tags = system.tag.readBlocking(tagList)
headers = ['Sample']
data =[]
for tag in tags:
	data.append([tag.value])
print(convertData)
@victordcq and @JordanCClark Thank you for your help. both solutions are working.
Now I found a new error. I have a Flex Repeater that is set to use the said view as its path. I am trying to use a tag with a script transform to tell props.instances.
The problem is I get the error-> instances: array expected, object found
tagList = [’[default]Sample/Tag 1/tag’, ‘[default]Sample/Tag 2/tag’]
data =
for tag in tags:
print(convertData)
Got the output in Dataset[2 rows, 1 cols] format.
Please give me any suggestions?
a flex repeater needs an array of objects as argument.
you will need to turn your data into something like this:
(instanceStyle and instancePosition are optional)
instanceStyle = {}
instancePosition={}
data = []
for tag in tags:
  data.append({'Sample':tag.value,'instanceStyle':instanceStyle,'instancePosition':instancePosition  })
return data
