Converting Array Value from Query
Hello all,
I am currently struggling with displaying data as an integer that is being pulled via a query. I have created a view where I use the following script to sum up the total value of that platform so I can display it in several textboxes, one for each of the platforms. I run this script from a dropdown filter set to current day (unless modified):
#Variables for table filter
date = self.props.value
shift = self.getSibling("Shift").props.value
dateStart = self.custom.filterDate
dateEnd = self.custom.filterEndTime
#Filter the table on startup
if date != None and shift != "":
	#Fill compact totals
	returnedData = system.db.runNamedQuery("Totals/Compact", {"dateStart" :dateStart, "dateEnd" :dateEnd, "shift" :shift})
	self.parent.getChild("Body Box").getChild("Units Box").getChild("Compact Units").props.text = returnedData
	#Fill FSOU totals
	returnedData1 = system.db.runNamedQuery("Totals/FSOU", {"dateStart" :dateStart, "dateEnd" :dateEnd, "shift" :shift})
	self.parent.getChild("Body Box").getChild("Units Box").getChild("FSOU Units").props.text = returnedData1
	#Fill horizon front totals
	returnedData2 = system.db.runNamedQuery("Totals/Horizon Front", {"dateStart" :dateStart, "dateEnd" :dateEnd, "shift" :shift})
	self.parent.getChild("Body Box").getChild("Units Box").getChild("Horizon Front Units").props.text = returnedData2
	#Fill horizon rear totals
	returnedData3 = system.db.runNamedQuery("Totals/Horizon Rear", {"dateStart" :dateStart, "dateEnd" :dateEnd, "shift" :shift})
	self.parent.getChild("Body Box").getChild("Units Box").getChild("Horizon Rear Units").props.text = returnedData3
	#Fill VMAX totals
	returnedData4 = system.db.runNamedQuery("Totals/VMAX", {"dateStart" :dateStart, "dateEnd" :dateEnd, "shift" :shift})
	self.parent.getChild("Body Box").getChild("Units Box").getChild("VMAX Units").props.text = returnedData4
	#Fill VMW classic totals
	returnedData5 = system.db.runNamedQuery("Totals/VMW Classic", {"dateStart" :dateStart, "dateEnd" :dateEnd, "shift" :shift})
	self.parent.getChild("Body Box").getChild("Units Box").getChild("VMW Classic Units").props.text = returnedData5
	#Fill VMW HE totals
	returnedData6 = system.db.runNamedQuery("Totals/VMW HE", {"dateStart" :dateStart, "dateEnd" :dateEnd, "shift" :shift})
	self.parent.getChild("Body Box").getChild("Units Box").getChild("VMW HE Units").props.text = returnedData6
	#Fill Total
	returnedData7 = system.db.runNamedQuery("Totals/Total Units", {"dateStart" :dateStart, "dateEnd" :dateEnd, "shift" :shift})
	self.parent.getChild("Body Box").getChild("Units Box").getChild("Total Units").props.text = returnedData7
This sets the textboxes to an array (as it is pulled from a query). For example: for today's date, I have [{"":2}] for the unit value for the "Compact" platform. Is there any way to get this to display the 2 without the additional array info?
Thanks in advance.
If your queries are returning a singular value that you want to display, then change the query type in the named query to Scalar Query. This will cause the query to return a single value and not a dataset/array.
Side note, I have no idea what your database structure is, but I would consider using a single query with table joins to get all your totals in one shot. Then you can assign each value to the corresponding label.
You are my hero. Thank you very much, I've been wondering what Scalar Query did. I'm still newer to developing, so this was a huge help. I will look into using table joins.
If you do a table join and get multiple totals in a single query, then you can't use scalar. Instead, you would do this
# Example data
row | total1 | total2 | total3
0   | 22     | 44     | 66
results = system.dataset.runNamedQuery("someQuery",{})
pyData = system.dataset.toPyDataSet(results)
for row in pyData:
    label1= row['total1']
    label2= row['total2']
    label3= row['total3']
You wouldn't need a loop though.
something like
label1, label2, label3 = pyData[0][1:]
should work
True, since the OP is newer to Ignition, I'm sure they will need to loop over a dataset at some point which is why I did it that way.
Good point though for a one-liner option, but the first column is just an artifact of printing the dataset, so it would be this I believe
You don't need the [:] then.
Ah, yeah you're right. Python would unpack it automatically :slight_smile:
EDIT:
One thing to note about the one-liner method, if the query was ever changed where the column order is altered, then the label assignment would be incorrect.
By explicitly indexing by column name, ie label1 = pyData[0]['total1'], the script would be more robust
