Hello. This is my second forum post. I have a table which shows a dataset with a return format to JSON to allow onCellEditCommit to change the operators Skill Level on the job. There is also dropdowns used to add new operators to the specific line, workcenter and workstation. When they use the dropdown to select line, it filters to select only that line in the table (through a new dataset from a query selecting only Line = :Line). The same goes for workcenter (Line = :Line, Workcenter = :Workcenter), then workstation (Line = :Line, Workcenter = :Workcenter, Workstation = :Workstation) to narrow the table down for adding operators. When using the dropdown to filter the table, it returns a new dataset. I need this to return JSON to the table so that the onCellEditCommit will still work. If you attempt to edit the data on the table the way it is, you get this code:
Error running action 'component.onEditCellCommit' on Configuration/SkillMatrixInsert@D/root/Table: Traceback (most recent call last): File " ", line 4, in runAction TypeError: 'com.inductiveautomation.ignition.gateway.datasource.BasicStreamingDataset' object is unsubscriptable
Is there a workaround for this or is this method simply not going to work? I have tried using the return format on the dropdown as well as a transform script to make the dropdown convert to JSON, this doesn’t work either.
