Converting string to java.util.date
Hello All,
I’m in need of to compare a time interval between two time_stamp
where one from database and for another i use system.time.now() function
then to calculate time difference i used function called system.date.minutesBetween()
when i passed the 2 arg inside this function the first arg from database is showing like
TypeError: minutesBetween(): 1st arg can’t be coerced to java.util.Date
Any suggestion would be appreciated
If it’s coming in as a string, try using system.date.parse().
What is the column type in the database table where the date is stored?
it was timestamp without timezone
And it’s coming in as a string? Or are you coercing it to a string?
What datatype do you get when you use something like print type(myTimeStampValue)?
Hi @JordanCClark,
Sorry for the delay in reply the datatype was not a string it’s an arrayList
Thanks & Regards,
Sri
Well, that’s because you grabbed it as a list. :wink:
What about type(sri[0]) to get the type of the first value of the list?
Hey sorry @JordanCClark,
it was <type ‘java.util.Date’>
Regards,
Sri
No worries, Sri.
Huh. Well, there shouldn't be an issue with minutesBetween() then.
That’s fine man i used some other methods actually my requirement was changed from checking DB time to current time
Sri
