Converting the values of a dataset to a JSON string in WebDev
Hi there! I have a query tag that is querying a DB table and putting the values into a dataset, and I need to be able to convert this dataset to a JSON string so that I can make it accessible through WebDev via http doGet. Is there a way to convert this dataset to a JSON string within the WebDev python resource, or do I need to set up some other script to convert it first?
Thanks!
You can put your own custom python into the WebDev module. You will want to return from the python resource a dictionary in the following format:
return {"json": <JSON String>}
You can make your own script for the Dataset to Json conversion or I found the following forum post with a solution.
