Corner Priority not Showing on Individual Views in Ignition Perspective
I want to set different corner priorities for a different screens in Perspective, but I only see a corner priority setting in the "Shared Settings" section of the Page Configurations. According to screenshots in the user manual there should be Corner Priority selector on each screen that lets you choose "left-right", "top-bottom", or "inherited", but that doesn't show up on my screens - example below:
Is there a setting that I didn't toggle?
What version are you using?
I see it on mine and I'm also in 8.1
I also wonder if it has to do with the screen you are viewing it on (mine is below 'Page Title')
No, you mean Pages (which are made up of views).
Figure 1. Note the title of the dialog is Page Configuration.
As you add pages to the Page Configuration list you can set the Corner Priority for each.
... but that doesn't show up on my screens pages - example below:
If you're still in trouble post another screenshot showing the list of pages with one (other than "Shared settings" selected.
Here's another screenshot, I'm on Ignition 8.1. I don't see a Corner Priority setting for any of the Pages that I've added to the project.
I have it on 8.1.43.
What resolution are you running this in? What specific version are you running?
EDIT: I tried shrinking my window down in an effort to cover the selector. A scrollbar appears when I do.
I am on 8.1.37, which I'm pretty sure should allow this functionality. I also tried messing with my resolution to see if the bottom panel was covering it, but that didn't work.
It appears in an 8.1.22 version that we have running.
Do you want to have different corner priority on your different pages? If you can live with shared them all being the same it should default to inherited.
Otherwise I would do some trouble shooting, try another project on the same gateway, see if that also has the same issue.
Seperate note for all of us on anything less than 8.1.55, see the CISA warning here
Solved the issue - it turned out to related to the resolution after all - I'm working through a remote desktop connection, and I changed it to 1920 x 1080 and Corner Priority showed up.
