Count number of tags with value x and add to a dataset
Hi hope someone can help me on this one.
I am looking to loop through a set of tags and depending on their value add each tagname to a dataset depending on the value.
Say I have 100 tags and each can have the value 0,1 or 2.
Loop through said 100 tags and add to either dataset 0,1 or 2 depending on the value of the tag.
These datasets would be bound to a template repeater to show devices that are 0(Tripped) 1(Reset Required) or 2(Healthy).
Any pointers on this one would be greatly appreciated.
Thaks
Do you have different templates for different statuses ?
If that's the case, I'd try to change that so there's no need to split your data, send everything to the same repeater.
If you wanted them sorted by status, then you'd just need to... sort the dataset.
Are the tagpaths available as a list? If so the task will be easy.
The templates are the same for each status but they would update depending one the current status.
The end goal is to be able to have 4 screens.
screen 1 would be all devices
screen 2 - tripped
screen 3 - reset required
screen 4 - healthy
I dont have them in a list at the moment but they would be sequential ie
Machine 100
Machine 101
Machine 102
Machine 199
So might be able to add to a list?
I'd put everything in one dataset, then filter it depending on user interaction. You can even simulate tabs if that's the look you're after.
I'll suggest one way of doing it, which may not be the best way, but that's a start at least.
I expect there's a more performant way of doing this with only epxressions if you're willing to install @pturmel's integration toolkit module.
step 1: read everything and make it a dataset
In your script library, add a python function like this (more about this later):
def build_dataset():
	paths = ["machine {}".format(n) for n in xrange(100, 201)]
	values = [qval.value for qval in system.tag.readBlocking(paths)]
	return system.dataset.toDataSet(
		['tag_path', 'value'],
		[[path, value] for path, value in izip(paths, values)]
How exactly to build the paths will depend on... the paths. This should make 100 paths in the format "machine n" for all n between 100 and 200 (included)
step 2: pull the dataset to your window/component/whatever:
Add a custom property to your window, let's call it "full_data", of type dataset.
Add an expression binding to it, and use this expression: runScript('path/to/build_dataset', 5000)
You'll need to adapt the path of the function (you can right click a function name in the right part of the script library editor to copy its path).
The "5000" here means the script will be executed every 5 seconds. Change this to match the refresh rate you want. 0 will make it run just once.
step 3: make another function to filter your dataset
Something like this:
def filter_dataset(ds, values):
	data = system.dataset.toPyDataSet(ds)
		list(ds.columnNames),
		[row for row in data if row['value'] in values]
This will return a new dataset with only row where the column value matches an element in the values list passed to the function. This means that calling filter_dataset(ds, [0, 1, 2]) will return the full dataset in your case.
More about this later as well.
step 4: use this function to populate your template repeater
Now all that's left is to add a repeater to your window, some way to allow the user to pick a status (dropdown, buttons... whatever), and bind the repeater's data to both the full_data custom property we made earlier and the user selected status.
Use an expression binding again, with runScript('filter_dataset, 0, {path/to/full_data}, {path/to/selected_status}')
I don't know whether runScript expressions reevaluate when one of the parameters change. If they don't, you'll need to change the pollrate to something that's not 0.
That's it.
Now, about the functions. Those will only be usable in this use case... which is a bit of a shame. If you ever find yourself in a similar solution, you'll need new very similar functions.
So, I'd suggest putting them in a custom library that contains reusable, generic functions.
The first one could be something like:
def tags_to_dataset(paths, columns_names):
		columns_names,
Which means you'll need to build your paths list separately. Which, at first sight, adds a layer of complexity, but is actually simpler in the long run.
Just make a new function specifically for that use case, which will build the paths list then call tags_to_dataset:
	return tags_to_dataset(paths, ["tags paths", "values"])
The filter_dataset function can go through a similar process.
The simplest way to make it more generic is to get rid of the hardcoded column name to filter on:
def filter_dataset(ds, values, col_name):
		[row for row in data if row[col_name] in values]
And change the expression binding to `runScript("path/to/filter_dataset", 0, {path/to/data}, {path/to/selected_status}, 'values').
Another way would be to instead pass a filtering function, that would be called to filter the data. But let's not go there right now.
Last thing to note: Those are simple and naive functions, and it would probably be a good idea to make them more resistant to failure.
What happens if some argument is not of the right type ? If a dataset is empty ? if... ?
But this is also a discussion for another time. For now I need to go and call my grandmother, she's celebrating her 99th year on earth Today.
Yes it will reevaluate when a parameter changes value.
One things to note... if ou are doing the readBlocking in a runScript, that will more than likely freeze the gui for a time while it is doing the work. For tasks like this I will usually have a timer component on that page that uses system.util.invokeAsync to read the data and then updates the gui with system.util.invokeLater. That way the gui doesn't "lockup" while the tags are being read.
Congrats!
Thank You :grinning:
