Count seconds since start with reset condition and use the value within vision
Hi together,
I want to count the seconds since shift start (daily 6am / 2pm / 10 pm).
My thought was using a transaction group with a tag and hour meter and use a variable that changes its value 6am/2pm/10pm to reset the hour meter (reset condition).Do I have to constantly query the database for the stored value of the hour meter or is there a possibility to grab the value directly from the transaction group tag?
Or is there another simpler possibility to count seconds since starting timestamp to use this value in vision? I want to multiply the value of seconds with the production rate per minute to get a theoretical production value (target production).
Thanks in advance!
You can use a gateway scheduled script to read a starting timestamp tag, and calculate the seconds past and other logic at your specific times.
now = system.date.now()
system.date.secondsBetween(startTime,now)
Or if you want more of a real time progress you could use an expression tag using your start tag.
secondsBetween({[.]start},now())
which can be used in a gateway scheduled script, transaction group, or another expression tag.
